Quick oil pump question
I just built my B18c1 and used oem everything. Its all together and ready to crank up. And this morning i came across a thread of rtv sealant being caught in oil passages causing engine failure. It started to make me second guess something, so i had to ask opinions. I used a new oem oil pump and gasket. I used honda bond and liberatelly applied it to the mating surfaces and alittle around the neck where the o ring is. I even put a little around the oil ring. I didnt globb anything on the pump. In your opinion, would i be ok?
Well normally it only take around 1 hour for it to become fully rubber like. RTV, Room Temperature Vulcanized. If you have waited enough, then it shouldnt be any problem. I redid my differential with RTV and a new gasket and i seriously vulcanized that puppy lol
i bought them here http://hondapartsnow.com
They have great service, and they also have cheap parts.
And a cool feature that lets you save your car so next time you visit the site your vehicle info is already there.
hope this helps
hope this helps
90AccordSi
Jan 6, 2012 04:28 PM
DumpedSi
Dec 7, 2003 07:59 PM
