Questions about fuel pressure regulator
Old Dec 23, 2011 | 07:02 PM
Salami's Avatar
Default Questions about fuel pressure regulator function
How much pressure change should there be on a stock regulator when disconnecting the vacuum hose? 96 B18C1.
Range for my motor in the Helms is 38-46 psi with the hose on. 47-54 psi with the hose off/pinched.
On my car the pressure under vacuum is set at 42 psi. Hose off/pinched it goes to 48 psi. Pressure is in range according to the Helms. Car runs rich though under idle/light throttle. If I use the B&M add on regulator to lower the pressure to the lower range given in the Helms the pressure is not where it should be under full throttle.
Mine is 6 psi difference from hose on to disconnected/pinched. Is this normal or is my FPR worn out and need to be replaced?
Old Dec 24, 2011 | 07:07 AM
chopstick88's Avatar
Default Re: Questions about fuel pressure regulator
6 psi is an alright change. What's your pressure without the regulator? I'd be more comfortable going with a aftermarket fpr.
Old Dec 24, 2011 | 08:07 AM
Salami's Avatar
This could be a dumb question, but how can pressure be measured without the regulator? I can't think of any easy way nor reason why removing the regulator would be relevant.
Notorious_T
Nov 2, 2008 03:02 PM
bigislandc2
Nov 12, 2006 06:42 AM
crxtreme27
Feb 4, 2003 08:28 PM
TakaIntegra
Jun 18, 2002 06:30 AM
MUGENTYPER
Jan 28, 2002 05:20 PM
