question on stock injectors and rail
cant find anything on this subject. i have a b18b and i know the stock injectors and rail are only good up to a certain amount of hp, but does anyone know what that number is?
Here is a calculator to help you out, its at the bottom. Read the notes regarding the brake specific fuel pressure.
http://www.rceng.com/technical.aspx
Here is a calculator to help you out, its at the bottom. Read the notes regarding the brake specific fuel consumption.
hmm, i actually might adjust my estimate down some. i looked through a bunch of dyno sheets on the evans tuning site, most 200whp builds had a least 310cc injectors. i did see a 186whp itr w/ stock injectors and i believe a 192whp ls/vtec w/ stock injectors.
maybe tuner with some NA experience can chime in
ya they are all 240cc i read somewhere. ill probably just use the stock stuff until i cant anymore.
no. an aftermarket fpr instead of an oem fpr. you can adjust the base fuel. itll raise the pressure to flow more then 240cc at 42 psi. instead it would be 330cc +/- at 90 psi so to speak. that is, if you have the fuel pump to do that.
yea, but the stock pump can only handle so much, rail is good to 750ish tho. a friends car has had the oem rail and oem fpr for years, full tilt it make 754 last time on the dyno.
my setup is a ported ls head, valve job, crane cams and valvetrain. probably blox IM and TB. so does it look like i can run all the factory fuel components?
JDM turbo DC
Mar 24, 2006 05:44 PM
filipinium
Sep 3, 2002 10:09 AM
