Question about cam install, no vtec?
Me and my friends installed a gude race cam into a friends 95si hatch.. Now the car will not hit vtec.. I dont understand.. I double checked all the plugs and everything is good. The car idles fine and runs good but just no vtec.. Any ideas??
did u make sure all the rocker arms are equal and flat lying. if not the pins in them might be ingauging but running into the side of the other rocker arm. just a guess but i noticed they would get stuck and lie unflat when i put in my ctr cams.
make sure all the valves clearances are adjusted to gude specs, if you have a 98ex (d16y8) cam in a 95si (d16z6) you'll need an adjustable cam gear, because the z6 is timed ~5* faster than the y8 (or so i've heard)
Theres a little dowel pin and rubber oring that goes in cam journal 3 make sure you put that back in...That will cause vtec not to ingage.
91integraLSVTEC
Jan 14, 2009 11:08 AM
Jap_Spec_Imports
Apr 13, 2008 09:47 PM
Johnny_9
May 13, 2006 05:35 PM
