ps belt
how do i put a ps belt on my b18, the belt is to short for the distance from the pump pulley to the crank pulley, is there a way to adjust the pump pulley to bring it in clocer or something like that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike banX »</TD></TR><TR><TD CLASS="quote">which bolts are the adjusting bolts</TD></TR></TABLE>On mine, the 2 mounting bolts are in long slotted holes. Loosen them just enough so the entire pump can slide on it's mounting bracket.
Then there's a long skinny bolt up top, with a head like a wing-nut. When you unscrew that, it lets the pump slide down so you put the belt on. Tighten it to tension the belt, then tighten the mounting bolts.
mrfootball420
Aug 30, 2009 05:42 PM
