problems starting car...
Old Jun 11, 2005 | 09:36 AM
sl01's Avatar
Default problems starting car...
Well here is the thing when i start my car when it's cold it works but when i try to start the car after i get done driving it when the engine is hot then it wont start, it doesnt turn over just nothing. I got my starter checked and that's not the problem,got the battery tested and that's not it, i'm just out of ideas. i'm tired of NASCAR STARTING it can someone help me???
Old Jun 11, 2005 | 11:50 AM
Crazydave's Avatar
Default Re: problems starting car... (sl01)
Check the connections on your battery and starter
Does your car die when it's running?
if so, You could check your main relay, the solder is known to crack.
You can pull it out and take a close look.
Old Jun 11, 2005 | 12:19 PM
sl01's Avatar
Default Re: problems starting car... (Crazydave)
it doesnt die when i'm driving it only when i turn the car off. When i try to restart my car it seems as if there is not power running to the starter. i wonder if its the cable that's running from the battery to the starter is bad what do u think??
Old Jun 11, 2005 | 12:24 PM
Crazydave's Avatar
Is the transmission grounded, are the cable corroded?
are you sure it's not the starter?
Old Jun 11, 2005 | 12:28 PM
sl01's Avatar
well i had the starter tested. i jus got done pulling the cables out so i'm goin to buy a new set and see if they work.
Old Jun 11, 2005 | 01:38 PM
NITROUSHONDA's Avatar
check your ignition switch
ATS*Mark
Oct 5, 2019 05:01 AM
layzie21
May 5, 2009 09:30 PM
skn181
Mar 23, 2007 06:02 PM
NoVALude
Jun 12, 2006 07:04 PM
cdn_cd5
Aug 30, 2004 03:44 PM
