problem after a/c install
hopefully i can get some help on my first post. i usually post at houston-imports but maybe i'll get a better response here ...
i have a jdm b18c itr engine in my 99 Si, after i installed the a/c the car surges when the a/c is turned on. the car pulls forward after i turn the a/c off, and if i turn it on the car it loses power. there is a significant difference in performance between when the a/c is on and off. any suggestions ? definately feels like an electrical issue
i know that, but this has to be abnormal. do you think this could happen if the compressor was bad. i've had a noise that comes from either the wheel bearing or a/c in high rpms.
Take off the AC belt & see if the noise goes away.
Your IACV is supposed to hold the idle steady when the AC clutches in & out, but maybe your AC has more drag than normal. Especially if the AC is the source of the noise...
Is it possible the AC is over-charged?
plotomatic
Sep 24, 2016 11:10 AM
wickedmaniac
12
Jun 6, 2014 08:18 AM
P-DuBB
23
Aug 8, 2005 10:36 PM
