Power steering pump battle
Old Feb 16, 2015 | 01:22 PM
pentaq's Avatar
Icon6 Power steering pump battle
hi,
the bearing in my power steering pump started to make a terrible noise. I bought the proper bearing (NOK with one side sealed). Disassembled the pump, replaced the simmering and the bearing. Assembled all and everything was OK. Nice and quiet. But after short time I found some power steering fluid drops hanging behind the pulley and noticed that pulley is wobbling quite a bit while rotating. What went wrong? I suspect that wobbling makes an axle moving up and down an this move casues a leak in the pump.
Any suggestions?
Thanks
Old Feb 16, 2015 | 01:28 PM
Tyler Dirden's Avatar
I am Jack's...
Default Re: Power steering pump battle
Aren't there two bearings in the pump?
Perhaps it's the internal bearing that is allowing the pulley to wobble?
I have never opened a pump up and have opted for salvage units because of time and cost. They rarely fail unless terribly neglected or freak issue.
Good luck
Old Feb 16, 2015 | 11:50 PM
VeeSykkz's Avatar
if a bearing failed to the point it got loud, it did damage. Why did you opt for the bearing instead of a rebuilt pump? They are as good as new if not better and you know nothing else is wrong with it.
Old Feb 17, 2015 | 02:08 AM
pentaq's Avatar
Cheaper at that time. And the pump looked brand new inside except the bearing and simmering, so I gave a chance.
Sortamorbid
Mar 6, 2014 02:01 AM
EFSiR
Honda CR-V & Element
Mar 3, 2013 06:05 PM
preludeMOM
May 1, 2007 04:17 PM
RACEPAK
Nov 20, 2006 08:08 AM
