is this possible:?
Old Feb 11, 2003 | 09:46 PM
CrazyKoreanCrx's Avatar
Default is this possible:?
A b16a2 is a hydo-transmission right? Well my question is can you put a cable-transmission on it or not? I need to know before I buy a short block and if it is a b-series it should it on it then right?-Thank you -
Old Feb 11, 2003 | 10:03 PM
sgT's Avatar
sgT
Default Re: is this possible:? (CrazyKoreanCrx)
yes you can interchange the transmissions. just need to make sure the
clutch disc matches the trans you are using. 90-91 are different than 92+
Old Feb 11, 2003 | 10:35 PM
Default Re: is this possible:? (sgT)
What about the flywheel?
Old Feb 11, 2003 | 11:20 PM
1SlowB16EF's Avatar
interchangable!!!!
Old Feb 11, 2003 | 11:34 PM
.(Lazarus).'s Avatar
Default Re: is this possible:? (1SlowB16EF)
interchangable!!!!
yup, I have an aluminum flywheel for a 90-93 Integra in my hydro tranny.
DA is best
Transmission & Drivetrain
Dec 30, 2010 11:10 AM
Teglessb18
Nov 28, 2006 06:12 PM
efhonda91
Mar 23, 2006 04:40 PM
spcrxracer
Sep 16, 2004 10:54 PM
cornhusker
Mar 5, 2004 09:18 AM
