Please help - D15B Oil pan gasket
Old Oct 15, 2020 | 11:44 AM
semse2's Avatar
Default Please help - D15B Oil pan gasket
I have a Honda civic '00 LX with an JDM D15B engine mounted and the oil pan gasket it is very bad and leaking oil big time so I need to be replace ASAP but I don't know which one is the right fit part since the old gasket doesn't have a part # , can someone help me out ASAP so I can order it ASAP ? thanks . Also, what can of High-Temp RTV Silicone Gasket Maker can I use ?
Old Oct 15, 2020 | 10:16 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Please help - D15B Oil pan gasket
Get an oil pan gasket for a USDM D16Z6 and some Genuine Honda Bond and you will be good to go.
Old Oct 16, 2020 | 09:57 AM
semse2's Avatar
Ok thanks for the information, I could order the gasket as USDM D16Z6 and you are correct it is the exactly fit . Thanks a lot!
Old Oct 20, 2020 | 06:43 AM
semse2's Avatar
My question is why the part is compatible with non vtec JDM D15B since the USDM D16Z6 is 1.6 and the non vtec JDM D15B is 1.5?
Old Oct 20, 2020 | 07:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Commonality in manufacturing... many brands share parts for multiple platforms. It is the way of the world.
VTEC or non-VTEC is a cylinder head issue... this has nothing to do with the oil pan. The displacement difference is due to crankshaft differences... the bore size of these two engines is the same. Since the oil pump, oil pick-up screen, windage tray and rear main seal cover are the same, it is not a stretch to think that the oil pan and gasket would also be the same.
