piston ring stoppers??
Old Apr 19, 2011 | 10:11 AM
umair's Avatar
Default piston ring stoppers??
my motor is at the machine shop and they guy said that my motor needs ring stoppers so that the bottom oil ring does not bend or break...i know it has the 2 thin rings on the top and bottom but i have never heard of ring stoppers..does anyone know what he is talking about and if you do where can i find them?
i have a 81mm b16 with je pistons, eagle rods/ and eagle crank. i have oem honda rings.
thanks
Old Apr 19, 2011 | 05:02 PM
PittsburghNBP's Avatar
Default Re: piston ring stoppers??
I cant even find any information on ring stoppers. the only thing that comes up is ring stoppers for like go carts and rc cars. thats weird.
Old Apr 19, 2011 | 05:40 PM
umair's Avatar
i know thats the scary part,lol. i dont know what hes talking about. maby its called something else but i cannot find any info either.
Old Apr 20, 2011 | 06:07 AM
fcm's Avatar
fcm
Old Fart
Why not go to the shop and have the mechanic show you what he is talking about? 94
Old Apr 20, 2011 | 10:04 AM
umair's Avatar
well here is what he is talking about...
this is a ring stopper or a ring guard...
this is my piston..
both next to each other.
he says there should be another ring that goes on the bottom and that ring does not move like you can move the other rings. its also a lot stronger. i dont know if you guys can see the nipple in the last pic that prevents it from moving..
Old Apr 20, 2011 | 11:51 AM
West Werks's Avatar
They are called Rail Supports.
When the piston pin bore is moved up into the oil ring groove (usually from a stroker crank or longer rod), you need support for the thin rails that make up the oil ring.
Call JE, they should be able to help you out.
Old Apr 20, 2011 | 02:33 PM
fcm's Avatar
fcm
Old Fart
I was wondering if that is what the mech. was talking about, as I have never heard of "piston ring stops" even Googled it and nothing came up. 94
Bizio
Engine Machining & Assembly
Jan 24, 2016 04:31 AM
acuralovar
Feb 10, 2010 01:48 PM
Sr420Det
Nov 15, 2007 02:38 PM
integ401
Apr 22, 2007 04:31 PM
SweepeR 7
Nov 8, 2003 08:41 AM
