Piston Ring Gap
I have a B18B bored out .20" over and im putting CP pistons in. The overbore piston rings that came with the pistons are out of spec but under the service limit. The top ring is .55mm. The factory spec calls for .20-.35mm with a service limit of .60mm. The second ring is alot better and very close to spec. Will this motor have blowby, will it burn oil? What should I do? I was about to put it in but im worried.
B19CivicHB
Jun 19, 2003 04:15 PM
