Is a P61 ECU a bad idea to use on a B18C1??
Old Nov 26, 2007 | 09:18 AM
EG6 Poe's Avatar
Default Is a P61 ECU a bad idea to use on a B18C1??
I just put a JDM B18C1 into my EG. I had a B16 before. Is it a bad idea to use a P61 ECU? What can be so bad about it? I heard its the same fuel map as the GSR, but without IAB control.
Also I can use the JDM P30 from the B16 swap. Thank you
Old Nov 26, 2007 | 07:56 PM
Hybrid96EK's Avatar
Default Re: Is a P61 ECU a bad idea to use on a B18C1?? (EG6 Poe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 Poe &raquo;</TD></TR><TR><TD CLASS="quote">I just put a JDM B18C1 into my EG. I had a B16 before. Is it a bad idea to use a P61 ECU? What can be so bad about it? I heard its the same fuel map as the GSR, but without IAB control.
Also I can use the JDM P30 from the B16 swap. Thank you</TD></TR></TABLE>
I'm not sure what you are trying to answer here... Can it be done? Sure. Is it going to run correctly? most likely not. Its BEST to have the ECU chipped and then tuned for your specific application. If you need something to get you by for the time being, the P61 would certainly do the trick. I'm pretty sure the P61 code is based off the P30 code, not the P72 code. With that in mind, they can't be exactly the same maps.
Old Nov 27, 2007 | 04:21 AM
mmuller's Avatar
Mad Scientist
as said, ill work but not good, fueling is less and timing is pretty high as stock b- series goes. highest one of all
hmoobthojboi07
Aug 29, 2008 03:35 AM
stripes777
Apr 13, 2006 09:01 PM
yellowmonkeyboy
Aug 26, 2003 11:16 PM
95cx
Feb 2, 2003 10:33 PM
SIK IN DA HED
Feb 20, 2002 04:11 PM
