Oxygen Sensor High Voltage : 1.3v
Old Mar 30, 2017 | 01:17 PM
nazim@skynet.be's Avatar
Default Oxygen Sensor High Voltage : 1.3v
I got a bizarre situation. Replaced my old Bosch sensors (refuses to go above 0.7v -65K kilometers) with new ones, and had my Engine Check Light. Reading from the OBDII, I notice that the other sensor was at 1.1v. And that was swinging beautifully 0.9 - 0v. But the one with 1.3v works intermittently. On the highway it seems OK but within city limits that damn CEL. I read somewhere that the if the ECU reads anything above the maximum (1.2v) in this case 1.3v it shuts out the calculations and operates on a default value. Can anyone clarify this for me. I thought of putting in a 3 ohm resistor in series with the return signal wire, in order to drop the voltage. So anyone here thinks it might work into fooling the ECU?
EKdriverin703
May 5, 2011 07:21 AM
BlueRex1020
11
Mar 23, 2007 08:06 PM
andyt
Feb 20, 2007 06:08 PM
89dohcEF
Dec 5, 2003 12:32 AM
