Which Oil Pump to Use Im Confused..
Old Mar 8, 2009 | 04:20 PM
CRXherbie91's Avatar
Default Which Oil Pump to Use Im Confused..
Alright, im building a B16A turbo.. the motor is OBD0 and its in a CRX i converted it to OBD1.. of course i need a b16 or gsr oil pump.. i know this.. but my question is.. i found a nice brand new oem honda oil pump on ebay for 95 bucks still in the wrapper.. BUT its for OBD2 and i know the OBD2 oil pumps have a sensor in them.. i know my ecu wont look for the sensor but will this cause any problems?.. i know the oil pump doesnt come with the sensor so i would have to find one an leave it unhooked.. can someone explain this to me.. or refer me somewhere to buy a oil pump that does not have this sensor..
Old Mar 8, 2009 | 05:13 PM
patriot's Avatar
Default Re: Which Oil Pump to Use Im Confused..
The OBD2 oil pumps dont have a sensor IN them. It's just a mounting point for the crank sensor that the OBD2 ECUs use...you don't have one so no biggie.
And don't get all hyped up whether it's a Type-R or not. All the OBD2 VTEC oil pumps are the same.
Old Mar 8, 2009 | 06:12 PM
locash's Avatar
Don't buy the obd2 oil pump, unless you also want to be forced to buy a new lower timing cover as well..
Old Mar 9, 2009 | 01:07 PM
92cxturbo's Avatar
that not a good deal either...
$97 http://www.acuraautomotiveparts.org/...s=&view=normal new from acura, the obd1 are like 30 more I think
Old Mar 9, 2009 | 02:13 PM
patriot's Avatar
But like locash said, with the OBD2 pump(which is what you listed) you need to get the lower timing belt cover and it ends up being the same price as a new OBD1 oil pump.
So it's really up to the OP which way he wants to go, but if he does get the OBD1 pump, he should remove the washer located at #12 in this diagram http://www.acuraautomotiveparts.org/...s=&view=normal
for a little bump in oil pressure.
Old Mar 9, 2009 | 10:05 PM
92cxturbo's Avatar
I was mearly agreeing with Joe
rak511
Feb 28, 2014 12:08 PM
fatboy803
Feb 14, 2010 05:28 PM
street_ride14
Sep 25, 2008 04:27 PM
Hockey27925
Mar 2, 2005 07:45 PM
hbkxtbone
Jan 5, 2005 04:12 PM
