OEM oil fiters....
Old May 30, 2002 | 09:31 PM
Ferrell's Avatar
Default OEM oil fiters....
i need to pick up an oil filter tomorrow but i have a problem.
nearest acura dealership is 45minutes away... nearest honda dealership is 15 minutes away.
Can i just get an oil filter from honda for my gsr??
Old May 30, 2002 | 09:50 PM
Ferrell's Avatar
Default Re: OEM oil fiters.... (94hondahybrid)
if i was to order one, id just order everything through ahmotor.com....but i dont want to wait. i plan on changing my oil tomorrow, and need it tomorrow.
thanks anyway
Old May 30, 2002 | 09:55 PM
Kamin's Avatar
Default Re: OEM oil fiters.... (Yes it's VTEC)
why do you NEED an oem filter?
fram, puroilator, etc.
any name brand works fine
Old May 30, 2002 | 09:58 PM
Ferrell's Avatar
Default Re: OEM oil fiters.... (KAMiN)
i know they will...im **** about stupid little things. go ahead, flame on, but its me.
OEM Honda
Old May 30, 2002 | 10:18 PM
JaeOne3345's Avatar
i work at a lube place when im not at school..just go get a 88-00 civic filter, it will work. and so will other models....but im too lazy to type them out...the new ones r different size on the new civics...but this one is for sure the same as a generic 88-00 civic.honda=acura=same ****.
Old May 31, 2002 | 12:48 PM
Chubz's Avatar
Default Re: OEM oil fiters.... (JaeOne3345)
yes a honda oem filter for civics work for integras also. Same filter
Old May 31, 2002 | 07:18 PM
jetdriven's Avatar
Default Re: OEM oil fiters.... (SuperTech)
use anything but fram. I read a report in the net about them, they came in dead last. I believe bosch, Mobil 1, and STP filters came in first (all the same manufacturer).
Old May 31, 2002 | 07:32 PM
Ferrell's Avatar
Default Re: OEM oil fiters.... (jetdriven)
thanks everyone. picked up an OEM filter from honda.
Old May 31, 2002 | 08:07 PM
Prelude Vtec 23's Avatar
By any chance do you have the link of that report?? Be nice to look at.
Old May 31, 2002 | 08:31 PM
MrTodd's Avatar
Default Re: OEM oil fiters.... (Prelude Vtec 23)
I've read that report - but I don't have the link, sorry. FYI: the bosch, mobil 1 and stp filters' construction is almost identicle to the OEM honda filters, same oil flow,durability and anti drainback reliability. The only difference is the filter material itself - bosch, stp and OEM honda filter material is OKAY, while the Mobil 1 filter medium is the best.
Now, if you lived in japan, the filter material for OEM honda would be as good as (or better) Mobil 1's. Some reason Honda decided to give us cheaper filters than the ones that they have - if you want ultimate performance/protection, definitely go with the Mobil 1.
[Modified by MrTodd, 10:36 PM 5/31/2002]
Old May 31, 2002 | 09:47 PM
the DR.'s Avatar
Default Re: OEM oil fiters.... (MrTodd)
we've taken apart an OEM honda filter at school and several other filters mentioned above and they all were almost identical, so its up to you on which one you get, my friend has and GSR and just uses honda filters so you shouldnt hava a problem.
Old May 31, 2002 | 09:54 PM
jetdriven's Avatar
Default Re: OEM oil fiters.... (CIVICtypeS)
heres the link for the honda filters comparison
http://www.ntpog.org/reviews/filters/filters.shtml
Old May 31, 2002 | 11:54 PM
quickspoolin's Avatar
Thank goodness, because I've been using Bosch for as long as I've owned my car.
Bosch=
[Modified by quickspoolin, 8:55 AM 6/1/2002]
Old Jun 9, 2002 | 08:46 AM
Chubz's Avatar
Default Re: OEM oil fiters.... (quickspoolin)
Fram sucks, I used their filter and the thread inside the filter stripped on me . Needless to say it took me 45 minutes to get the filter off. Im sticking with oem
Old Jun 9, 2002 | 01:03 PM
.Ryan's Avatar
Don't Trust Anyone
Hamp the green filter.
Atomic1
Jun 23, 2010 02:02 PM
b18cEK
May 4, 2004 06:18 PM
Galvatron
Oct 11, 2003 09:11 PM
zCivic
Sep 10, 2003 03:59 AM
