OBD2b - OBD1 Conversion & Tach doesn't work
Old Feb 20, 2008 | 02:55 PM
C_Rock77's Avatar
Default OBD2b - OBD1 Conversion & Tach doesn't work
I put a Hondata s300 in my 2001 GSR (installed in an OBD1 P28). Everything started up fine, but the tach did not work. The car was running, but the tach did not work at all. I pulled the Hondata unit out, threw in a stock OBD1 P72 and the same result occurred.
When the S300 was in the car, all the datalogging was working. RPM, Vac, etc. all were working on the display in the laptop. The gauge in my cluster just sat on 0. All other gauges worked: Temp, Fuel, Speedo. The tach just sat on 0. Pulled everything out, and put the stock OBD2b ECU back in, and everything worked fine.
The GS-R is SC'd and running the JRSC hack and FMU. It started throwing the code for the Atmospheric sensor. I picked up a Hondata S300 and was going to put the unit in and run a stock P72 map in it (still running the JRSC hack) until I can get the cash to take it to the tuner. Now, seems like I have other issues.
Any suggestions?!
Old Feb 20, 2008 | 03:36 PM
tony1's Avatar
Default Re: OBD2b - OBD1 Conversion & Tach doesn't work (C_Rock77)
I'd try another conversion harness. I see bad ones all the time.
Old Feb 20, 2008 | 05:29 PM
Blown90hatcH's Avatar
Many people that copy those harnesses and ***** them out don't remember to jump the tach wire. OBD2b harnesses need the OBD2b A19 wire jumpered with the OBD2b B13.....all going to OBD1 A21.
Old Feb 20, 2008 | 08:06 PM
C_Rock77's Avatar
Default Re: OBD2b - OBD1 Conversion & Tach doesn't work (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Many people that copy those harnesses and ***** them out don't remember to jump the tach wire. OBD2b harnesses need the OBD2b A19 wire jumpered with the OBD2b B13.....all going to OBD1 A21.</TD></TR></TABLE>
Think you're right....looks like that jumped pin that's a combination of wires from OBD2b B13 and OBD1 A21 is actually pinned into OBD2b A18, not 19. I wonder if it's simple enough that A18 & A19 are switched?
I can't figure out how to get these pins out of the plug...it's a one piece plug
Old Mar 30, 2008 | 11:14 PM
EARLdaSQUIRREL's Avatar
official honda whore
if i used an obd2 engine harness with obd1 body harness would i have this problem??
if so how could i fix it, as of now my speedo jumps a little bit when i hit the gas and my tach does not work at all!!!
Old Mar 31, 2008 | 04:33 AM
syntrx's Avatar
when you perform a conversion can you still pass emissions?always wandered that.
Old Apr 16, 2008 | 09:48 PM
C_Rock77's Avatar
Default Re: OBD2b - OBD1 Conversion & Tach doesn't work (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I'd try another conversion harness. I see bad ones all the time. </TD></TR></TABLE>
Tried that, Tony....any other ideas?
Old Apr 16, 2008 | 10:57 PM
mtber's Avatar
+2 the issue is in the conversion harness. Contact who ever you purchased it from.
Old Apr 17, 2008 | 02:43 PM
C_Rock77's Avatar
Default Re: OBD2b - OBD1 Conversion & Tach doesn't work (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
Well...you guys are both wrong. Contacted the manufacturer and it's not in the harness. The FIX can be done in the harness....the issue is something with the tachometer electronics. For people's future reference:
Modified by C_Rock77 at 5:48 PM 4/17/2008
Old Aug 10, 2008 | 08:59 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_Rock77 &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by C_Rock77 at 5:48 PM 4/17/2008</TD></TR></TABLE>
can anyone verify the trick?
Old Aug 11, 2008 | 05:06 AM
Default Re: OBD2b - OBD1 Conversion & Tach doesn't work (JDM turbo DC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM turbo DC &raquo;</TD></TR><TR><TD CLASS="quote">
can anyone verify the trick?</TD></TR></TABLE>
If the harness is not built properly....many cheapo egay copiers do this....then this fix can be used to get the tach to work properly.
Old Aug 11, 2008 | 12:57 PM
If the harness is not built properly....many cheapo egay copiers do this....then this fix can be used to get the tach to work properly.</TD></TR></TABLE>
heres the weird thing in my situation, my tach didnt work when i ran the greddy blue box with the conversion harness. When i removed the greddy blue box, the tach worked with the same conversion harness. Now I have my ECU chipped and again, the tach is not working
It seems that the resistor trick might make sense in my situation but when i double checked where the resistor is tapping into, A25 is a 12volt source so i dont want to fry the A21 input. Thats why i wanted some verification, thanks.
Old Sep 11, 2009 | 05:59 AM
Muckman's Avatar
Moderator in Chief
Shouldn't a good conversion harness already have this resistor wired in? This tach problem is apparent with EVERY OBD2b to OBD1 conversion so it doesnt make sense that it would fall short on this function.
Old Sep 11, 2009 | 06:56 PM
C_Rock77's Avatar
I CAN VERIFY THE TRICK! It worked for me! Wired in the Resistor and the Tach worked.
Old Sep 11, 2009 | 07:11 PM
Muckman's Avatar
Moderator in Chief
Can you take a pic of how you wired in your resistor for me please? I also put a 1k resister on A21 and A25 and my now tach moves but not past 1500. I think it may be because the A21 pin (ICM output) is split to both A19 (tach output) and B13 (ICM output). And now there is a resistor feeding 12v power to both the tach and ICM outputs.
Old Sep 14, 2009 | 01:58 PM
xenocron's Avatar
Do some tachs just require more "juice" than others?
Maybe the output is enough to drive the ignitor but not enough to drive the cluster?
Maybe some OBD1 ECUs have a weaker output?
We'll get this figured out!
Old Sep 15, 2009 | 03:30 AM
Actually no it is not. I have sold over 2000 of those harnesses and very few have ever had issues like this. You also have to remember, with the exception of one manufacturer left, all of these harnesses are built out of the country, in mass quantities by individuals that don't have a clue what they are being used for. Asking them to install a resistor into a harness will probably take the failure rate of the harnesses up by 1000%.
I sent you a PM. When it is at idle, does the tach match the idle speed?
Old Sep 15, 2009 | 01:11 PM
Muckman's Avatar
Moderator in Chief
Thanks Jason, I replied to your PM. With the resistor the idle is rougher than without the resistor. The ECU (Neptune) has always registered the rpm correctly. With the resistor the tach matches the ECU rpm. However when rev'd past 1500 the tach goes dead. Very strange.
What are your thoughts on this resistor "fix"? Is it way out in left field or does it sound logical?
Old Jan 17, 2011 | 06:31 PM
SiLEnT_ST's Avatar
I was womdering, can you do this resistor fix to a p72 obd2a ecu? Becuz the wires A21 and A25 from the obd2b ecu would be A11 and A20 on the p72 obd2a ecu. Should work right?
I got a obd2b (00' gsr) motor in my obd2a (96 gsr) shell. The engine harness for obd2b doesnt have the blue wire on the plug at the distributor and the harness from the car have the blue wire, which is for the rpm/tachometer. So my rpm doesnt work.
Old Jan 22, 2011 | 03:58 PM
infamouskillas's Avatar
I too have this problem with my tach not working...it works fine up until about 6000 rpms and then it just dies out zero...can anyone post a pic of how they wired the resistor in the harness? (if I understand correctly)..
Old Feb 21, 2011 | 11:49 PM
can anyone please post a pic of the resistor soldered in the pins? i need a reference!
Old Feb 22, 2011 | 05:48 AM
Muckman's Avatar
Moderator in Chief
Here is my adapter harness. I used a 1k resistor as instructed. This fix DID NOT WORK for me. I ended up running a seperate wire from the Dist into A19 (tach).
Old Feb 22, 2011 | 12:01 PM
SiLEnT_ST's Avatar
Yea, i end up doin what you did too.
Old Jul 23, 2011 | 09:36 AM
montis's Avatar
i have similar problem with tach. i have made auto to manual swapin my "00 d16y8 civic. it use obd2b harness, but after swap i use obd2b to obd2a jumper and obd2a ecu. and tach doesn't work....
Old Oct 28, 2015 | 03:08 PM
Vi_Nation's Avatar
Montis i did the samething and my rpm dont work i have a obd2 jump harness with a p28 it work fine on others car but mine it driving me crazy
