obd2 check engine code 13... baro sensor
Old Mar 26, 2005 | 01:12 PM
highboostb18c1's Avatar
Default obd2 check engine code 13... baro sensor
i know that the BARO sensor is my barometric press sensor. idon't have a scan tool and code 13 can be either too high or too low a reading. why would my car throw this code and what do i do to fix it>?
2000 integra gsr turbo
vafc2 hack
Old Mar 26, 2005 | 01:45 PM
TurboLSVtecTeg's Avatar
Default Re: obd2 check engine code 13... baro sensor (highboostb18c1)
Your hack is probably what caused it. Reset the ECU and hope it doesnt come back on.
Old Mar 26, 2005 | 02:14 PM
Default Re: obd2 check engine code 13... baro sensor (TurboLSVtecTeg)
could it be anything else? i drove 6 months last year and haven't changed a thing, the car has been sitting since september, all i changed was the turbo and when i last shut it off in september there wasn't a check engine code, now there is. why would the hack mess it up now?
Old Mar 27, 2005 | 08:48 AM
Old Mar 27, 2005 | 05:37 PM
PrettyLude's Avatar
its a faulty code, reset the ecu
Old Mar 28, 2005 | 06:49 AM
Iceman05's Avatar
nope, code 13 is b/c the hack is hiding boost from the map sensor, the baro checks itself against the map, finds an incorrect value and throws a code. nothing you can do about it except an obd1 converison. ive been living with the cel for a year.
Old Mar 28, 2005 | 09:06 AM
Default Re: (Iceman05)
i cleared the code for now, i want to do obd1 converison bt here in NY we have the worst inpections. can't have obd1 comp w/ hondata cause i won't pass.
phoenixyellowda9
Jan 31, 2008 08:03 PM
black_99SI
Dec 7, 2007 05:14 AM
ViXoN Hatch94
Apr 17, 2006 07:11 PM
EF8 JUNKIE9
Aug 7, 2005 09:54 PM
