O2 sensor location.......
OK on a b16a2 whats the o2 sensor location on the front of the header or on the rear section the header...... Does anyone know.. Does it matter what location it goes in... Or does it depend on what ecu type...Like obd 1 or obd 2... Any theories on it.
if you are using a 4 wire heated oxygen sensor it needs to go at the rear of the headers, not the front if it is OBD1.
(if it is OBD0 the two o2 sensors need to go closer to the exhaust ports on teh head.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio »</TD></TR><TR><TD CLASS="quote">where is it located on a 94 gsr?</TD></TR></TABLE>It's in the cat. But it's upstream of the catalyst material, so it counts as being before the cat.
Jmumblez2001
Jul 20, 2006 09:39 AM
