NSX caliper on delsol
well i was able to get some nsx calipers. i want to put them on the del sol si. my main concern is wich rotors to go with. not sure, i've heard prelude redrilled to 4x100, or can i just get nsx rotors? i'm woried about them being hubcentic. anyways just any info on this swap would help thanks.
best way to go about it would be to switch to a 5 lug, and use 94 GS legend rotors...search around a bit for NSX brakes...there are a couple of real good write ups in the archives and also on g2ic...hth
*edit*
or you should just give up on the project all together and sell me your nsx calipers...so baller!
*edit*
Its the Prelude VTEC rotors, has to be that model. They have to be redrilled to 4x100. Also, the brackets aren't going to clear, whether you use this rotor or the Legend GS rotor. They will need to be milled on the backside.
This is the result: Prelude rotor, NSX caliper.
dr_latino999
Suspension & Brakes
Mar 15, 2010 05:59 AM
GoldenONE
May 16, 2003 11:43 PM
