No spark
I have a crx b16 its obd1 now always drive fine.just recently my gf was driving it and it started then died. I changed plugs then wires then no spark still. After that I checked to see if the distributor was giving spark and it wasn't so I put another one and still no spark. I'm positive both distributors are good what could the the problem. I have blox b's so I thought the intake cam broke but it didnt. Do u think the jumper harness could of took a ****? Or timing deal with no spark?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-honda-civic-no-spark-%2A%2Afollow-up%2A%2A-2500934/
maybe this will help you out
If it has been running fine and all of a sudden it has no spark it has to be the distributor. Ignitor or Ignition coil. You can check the timing belt if you like to see if it skipped teeth or broke.
ef2 from hell
Nov 25, 2006 03:07 PM
