no injector pulse! help plzzz
Old May 10, 2011 | 05:26 AM
turboek03's Avatar
Default no injector pulse! help plzzz
i have a 98 civic with a turbo b18c1 running on a aem 1020 i replaced evrything restor box new msd dizzy and pretty much evrything that would cuz a problem. but i have now injector pulse i have power goin to the injector but wen i put a diod on the injector clips they have weak or sometimes no pulse and at this point im lost so can u guys plz lead me in the right driection thnks
Old May 10, 2011 | 03:56 PM
fcm's Avatar
fcm
Old Fart
Default Re: no injector pulse! help plzzz
The ECU/ECM supplies the ground pulse for the injectors, it needs the "signal", [12V+] from the injector relay [in the PGM-FI Main Relay] to the IPG1 and IPG2 for the ECU/ECM to pulse the injectors.
I would start looking at the ECU/ECM. 94
Old May 15, 2011 | 02:44 PM
1badda's Avatar
having same issue with my accord
Old May 15, 2011 | 04:14 PM
fcm's Avatar
fcm
Old Fart
Then it may be the same problem, check at the ECU/ECM does IGP1 a IGP2 have 12V+ when ign. switch is on? 94
Old May 15, 2011 | 07:32 PM
EMTIV09's Avatar
Make sure the ecu is getting the correct voltages and the the battery is able to produce the voltages. If all that checks out start checking the ecu ground points them selfs. I would suggest a pretty good multimeter. It's always simple crap that causes the biggest headches. Plus check your tune to make sure you have the right injectors selected.
Matthewhughes
29
Aug 5, 2014 03:18 PM
crxmadness
15
Jun 11, 2014 06:38 PM
fasteddief23
Jul 6, 2011 01:31 PM
mickey b16
May 18, 2009 07:33 PM
98vtec
Mar 18, 2008 07:36 PM
