No FI signal from ECU? Help!
Old Oct 26, 2009 | 07:23 PM
commguy's Avatar
Default No FI signal from ECU? Help!
I went on a spirited drive in my car (00 EJ8) after I got it home from being shipped, and it stuttered a little bit in the neighborhood on the way back to the house and shut off on this hill right down the street. It was pretty low on gas at the time, so I thought maybe the hill had put the little remaining fuel out of reach of the sending unit. I waited a moment and it started up and pulled into the driveway fine, no biggie I thought. I came back out to start it up the next day, and it just turned and turned and turned, no start. I pulled all the plugs and found no gas on any of them, and then thought perhaps the hill of my driveway had done the same thing, I dumped 3 gallons from a gas can into it, and still nothing. I undid the banjo bolt at the fuel filter to check for pressure in the line, and there was plenty of that, then I went ahead and just changed the filter, still nothing of course. I then became suspect of the injectors themselves, thinking perhaps some nasty, cruddy, dregs of the bottom of the gas tank had somehow clogged them up or stuck them shut. Before I started pulling injectors out and all that mess, I put a test light on the injector pigtail clip, cranked it a bit, and got nothing on the light, then I thought well, the pulse width a idle speeds is probably only like 10ms, the light may not be able to light up with that fast of a pulse. Then, seeing no other way, I pulled the rail off and zip tied the injectors into it, primed the fuel system (certainly thats not what its called, thats just what I call it when you let the fuel pump relay run for 5 seconds or w/e in the run position), checked my little zip tie injector rig for leaks and put a shop towel in front of the injector nozzles, then went and cranked on it, came back to inspect it and indeed I did not have any gas sprayed onto the shop towel. Then I used two leads directly from the battery to the injector pigtails and PSSSSHHHH they sprayed away. Then, thinking maybe I had just cleaned them of the suspected gunk, reconnected them and tried turning it over again, and no spray. Then, completely frustrated, I came inside and started searching, and found the attached fuel system wiring diagram, which sent me back outside to put the multimeter on the yel/blk side of the pigtail clips with the key in run to see if the fuel system is getting power, and it is in fact getting full battery voltage. Then I went and popped the hood on my EM1 and connected the test light to one of its pigtail clips, since I know it is working fine, and got some faint, but very consistent flashes on the light. I went back and re-did the test light on the EJ8 to confirm, and there were definitely no flashes
So, finally, after lots of troubleshooting, I am convinced that INJ-1,2,3,4 at the ECU are not functioning correctly, and that my ECU is bad.
I am here at HT to check my theory and troubleshooting steps against those minds with greater knowledge than my own before I proceed to buy another ECU.
Thanks for taking the time to read through this and if you have any thoughts please reply ASAP.
Old Oct 26, 2009 | 11:59 PM
KWayRacing's Avatar
Default Re: No FI signal from ECU? Help!
Does the mil come on for two seconds and then go out when you put the key in the #2 position? WHat is its status?
Old Oct 27, 2009 | 12:12 AM
commguy's Avatar
Sorry, not sure what you mean by "mil." Do you mean the CEL? In that case, yes I do have a steady CEL, but that was on previously for low O2 voltage.
Old Oct 27, 2009 | 07:49 PM
commguy's Avatar
I'm thinking about trying to run it with the P2T from my EM1, anyone see a problem with that? Obviously its not going to run very well, but I should be able to start it with the P2T if I am correct about the ECU being bad, right?
Old Nov 3, 2009 | 03:57 AM
JCB's Avatar
JCB
I am having the same problem with mine. I'm going to try the distributor first to see if that is what my problem is. I'll let you know how it goes. I did the same exact things as you to check everything, but still came up with no luck. Let me know if you find out anything that will help.
minxfinx
11
Dec 29, 2015 04:44 PM
Black R
Mar 11, 2011 04:59 AM
commguy
Oct 27, 2009 05:01 PM
MulletManRockStar
Jan 5, 2005 07:05 PM
Slingshot
Feb 24, 2003 10:05 AM
