No crank position sensor on JDM B18C? What do i do?
Old Apr 25, 2003 | 05:35 PM
speedymon's Avatar
Default No crank speed fluctuation sensor on JDM B18C? What do i do?
Just got the block and i'm installing it now. Took off the crank pulley of the B18C and noticed that it doesn't have a sensor there like my B18C1? I know i'm going to throw a code. What do i do about this and what are the effects?
Modified by speedymon at 12:01 AM 4/26/2003
Old Apr 25, 2003 | 06:39 PM
fulldragcrx's Avatar
lets get all the facts first so we can help. Year make, model, ecu, harness etc.... what are they ? but if you want me to guess i would say that the motor will not even start. youll need to adapt a usdm crank sensor over.
Old Apr 25, 2003 | 07:10 PM
speedymon's Avatar
Default Re: (fulldragcrx)
Whups sorry about that. I don't know the year of the JDM block though. It has an OEM oil cooler on the back so I think it's a 94-94 B18C OBD1. It's going into a 96 USDM GSR, stock everything OBD2 everything.
I tried jerry rigging the crank speed fluctuation from my USDM gsr onto the OBD1 JDM block but it WILL NOT FIT
Old Apr 25, 2003 | 07:19 PM
brainwo's Avatar
New User
Default Re: (speedymon)
Get a JDM spec p73 ECU.
Old Apr 25, 2003 | 08:05 PM
sleepN's Avatar
I think that the crank fluctuation sensor is an internal part of the distributor with OBD1.
Old Apr 25, 2003 | 08:33 PM
civicrtype's Avatar
Default Re: No crank speed fluctuation sensor on JDM B18C? What do i do? (speedymon)
I encountered the same problem puttin a obd1 LS block on my 98 EK. I heard it wont let u rev past a certain rpm w/o that sensor. So u got 2 choices. Add and oil pump w/the sensor or do what I did, Made a OBD2-OBD1 conversion harness and used and OBD1 ecu. Better route anyway since u can chip the obd1 ecu. Good luck.
Old Apr 25, 2003 | 10:12 PM
Lord Helmet's Avatar
you have a spare usdm obd2 distributor? try that.
Old Apr 25, 2003 | 10:43 PM
B20Monster's Avatar
Default Re: (sleeperciv)
if you still have the sensor from the old block.. all you gotta do is switch over the oil pump .. the sensor should be fine then.. if not.. .go to Honda/Acura and get an ITR oil pump.. its only like $95... and find a sensor elsewhere.. good luck .!
gsr-t9303
Mar 30, 2011 09:45 PM
Redbone
Feb 18, 2007 11:26 PM
86si
Jun 21, 2005 06:27 PM
