View Poll Results: would you fit new piston rings & NOT hone the block?
yes
28.57%
no
10
71.43%
Voters: 14. You may not vote on this poll
New Piston Rings - Without Bore Hone
as the topic title says really.
i know that the block should be honed when fitting new piston rings, however, it's an all about cost at the moment.
basically, i'm just looking for people's opinions on it.......
A new dingleberry (ball hone) is around 60-80 bucks and well worth it.
If your block still shows factory hone marks then new rings should be fine without rehoning. If you have access to a ball hone its worth running it through a few times just follow correct way to do it.
I am not an expert but this is the advice I would give myself and friends.
Its more important that the rings are installed in correct order and alignment and gapped.
Just make sure to warm engine up to temp and have a good enough tune to get on it right afterwards to seat the rings and allow them to file in correctly.
Again just my suggestion take it for what it is and do more research.
Definitely get it honed. The $60 U spend on the hone or $40 at a machine shop is WELL WORTH not having to tear down a block and put in new rod bearings, piston rings, and headgasket- plus time. Like sauceja said, make sure the rings are in the correct orientation and they are gapped to spec. It's also better to have them overgapped instead of undergapped b/c of heat expansion. I'd recommend not overgapping them on purpose, but over is better than under IMO.
KillaB-
Sep 15, 2004 09:45 PM
...VW that is. Rod bearings on a 2.0L in ~6hours
