In need of some opinions....
Old Feb 13, 2003 | 08:08 AM
breakneckvtec's Avatar
Default Setup for the Si....
I may be planning a small NA buildup. Its for a 99 Si with a b16a2 and will consist of this:
Skunk2 Stage2 cams
Skunk2 valvetrain
Skunk2 racing valves (comp bump .2)
Headgasket, dont know which maybe Mugen? (comp bump .4)
Skunk2 cam gears
P28 ECU, program and vafc? Hondata? <---need suggestion
Redline ~ 8600 fuel cut 8800 <--- sound right?
Ditch my shitty DC 4-2-1 header and go with a good 4-1 header <---worth it?
Skunk2 or CTR IM <---need suggestion, am I using big enough cams and reving enough for this?
Dyno tune, of course
I am trying to build a reliable, fun, quick street car. I will mainly autoX this car, got the suspension done already. I may drag race it every so often just for fun when theres no autoX events to get the blood going. A low 14, something at 14.4 or lower would be nice, is what I would be aiming for. With some good tires and a decent driver COULD it happen, I know there are tons of factors but I am interested in whether or not it has the POTENTIAL to pull a time like that. I would be using an Exedy clutch as well. The car would be stripped lightly, about 70lbs or so maybe 100lbs. Will I be disapointed?
[Modified by breakneckvtec, 8:57 PM 2/13/2003]
Old Feb 13, 2003 | 11:58 AM
Default Re: Setup for the Si.... (breakneckvtec)
Up please.
Old Feb 13, 2003 | 12:00 PM
kyle h.'s Avatar
if you've got the money to burn i dont think you will be dissapointed. sounds like a respectable setup. hondata would be nice, although fairly expencive.
jimmyjun0213
11
Mar 19, 2015 09:46 PM
92db2gs-r
15
Jan 19, 2011 09:20 AM
v00tecsi
Sep 22, 2003 02:57 PM
EK99hatch
Mar 16, 2003 07:01 AM
