need longer or custom radiator hoses
Old May 14, 2017 | 10:15 AM
slagman's Avatar
Default need longer or custom radiator hoses
90' CRX Si, DOHC ZC. I moved the (eBay) radiator forward and to the left a bit to make room for downpipe. Now I need about 2-3" inches more hose. I tried some of the Gates Vulco Flex but cant find the right diameter, it only comes as small as 1 1/4" and the outlets are little smaller. Maybe braided hose with AN fittings? Then I would have to thread the outlets on the housing and radiator right? I tried getting aluminum fittings with a bead on each end to extend the hoses but still cant find right diameter, either too big or too small. Couldn't find much on this topic either. Every thread ends inconclusively and is from 10+ years ago. Thanks.
Old May 14, 2017 | 11:35 AM
jdblock's Avatar
Default Re: need longer or custom radiator hoses
How about splitting the hose and installing an aluminum tube? Or if you have an aluminum radiator, having some pieces welded on to extend the inlet and outlet.
Old May 14, 2017 | 05:21 PM
slagman's Avatar
Thanks, yeah tried it but The diameter was too small and 1.25" seems too big, I think the housing inlets are smaller than the radiator outlet. Radiator outlet is 1.25". Are the oem hoses tapered or something?
Old May 14, 2017 | 07:08 PM
jdblock's Avatar
Not that I know of. I'd measure the OD of the radiator inlet and outlet themselves.
Old May 15, 2017 | 06:56 AM
slagman's Avatar
Aha, found a thread on D-Series.
32mm > 28MM Silicon Reducer - D-series.org
Looks like I have to go from 32mm to 28mm.
How the heck to you connect silicone reducers?
crxnug
Feb 3, 2006 07:26 PM
slim9300
May 1, 2004 09:48 AM
sloweh3
Feb 17, 2004 04:32 PM
B18EG6
May 5, 2003 11:36 PM
B18EG6
Apr 8, 2003 10:22 AM
