Need Help w/ my swap.
Old Mar 26, 2002 | 01:56 AM
strykr's Avatar
Default Need Help w/ my swap.
I swapped in a 91 dx motor into my 89 dx hatchback. I plugged everything in and the car will not start. It is firing but the car will not start. I know the motor has good compression and I am getting a spark. So I'm thinking it can it be w/ the fuel. I need help asap. Any ideas or suggestions I should try? Does anyone know the firing order of the spark plugs.
Old Mar 26, 2002 | 08:58 AM
Sonic's Avatar
Default Re: Need Help w/ my swap. (bomexciviccoupe)
The firing order is 1-3-4-2, with 1 being the bottom left of the distributor. listen behind the seats when you turn the ignition on to see if the fuel pump is pumping.
Old Mar 26, 2002 | 04:42 PM
strykr's Avatar
Default Re: Need Help w/ my swap. (Sonic)
TTT
nicknack25
Aug 22, 2010 05:56 PM
youknowwhoibee
68
Dec 3, 2007 06:24 PM
meloylo
Nov 9, 2007 12:22 PM
DOHClessEF-9
Jan 8, 2005 08:54 PM
EFPROJECT
11
Jul 4, 2003 01:42 PM
