NEED HELP QUICK
can i use a b16a iac valve thingy on a gsr manifold...some jackass sent me a gsr manifold with a single cam iac.. it lines up and everything...but when i start the car idle jumps straight to 4000 rpm's
i took apart the manifold and retourqued everything in order...still the same outcome...throttle cable is set perfect also...any suggestions...no codes neither...so i either have a leak some where in the intake, or i need a gsr iac valve and not a b16a..help please guys
b20turbojason
Nov 4, 2003 04:32 PM
kamciu80@aol.com
Dec 6, 2002 07:24 AM
