Need help with piston sizing.. Tried searching.. no luck!
Old Jun 15, 2003 | 09:41 PM
arsenaldragster's Avatar
Default Need help with piston sizing.. Tried searching.. no luck!
I have a stock b18b.. i am planning a rebuild so i figure im going to have it cleaned honed and possibly slightly bored out if needed.. Heres the question:
If i go say .20 over on a bore can I still run 81mm pistons and use oversized rings or do I need to find oversized pistons and rings? My dad says I need to get bigger pistons, for some reason I thought I could just get oversized rings.. Please help! TIA
Old Jun 15, 2003 | 09:47 PM
aeolus's Avatar
Default Re: Need help with piston sizing.. Tried searching.. no luck! (arsenaldragster)
you are gonna need oversize pistons.And youll have to have the block overbored by a machine shop.
Old Jun 16, 2003 | 09:15 AM
Default Re: Need help with piston sizing.. Tried searching.. no luck! (aeolus)
ttt
Old Jun 16, 2003 | 10:01 AM
1_bad_EF's Avatar
Dont go .020mm over just go 81.25mm using factory oversize(os) pistons.
you have to get both os pistons and rings.
Stealthmode Performance
Jan 19, 2012 09:58 PM
89hatcher
Mar 19, 2011 07:06 PM
DC4 Rasta
Jan 5, 2007 06:44 PM
ek
Jun 10, 2002 08:52 AM
