NEED HELP, LSD Tranny oil.........
Old Feb 23, 2003 | 08:25 AM
turbod92hatch's Avatar
Default NEED HELP, LSD Tranny oil.........
i have a friend and he just got his gsr tranny with a i guess a stock lsd. we were told that it needs gear oil. is this true. if so what weight, 75-80, 80-90. any suggestions would be appreciated
Thanks, Travis
Old Feb 23, 2003 | 08:41 AM
BabyDaddy's Avatar
Default Re: NEED HELP, LSD Tranny oil......... (turbod92hatch)
GSR's don't come with an LSD stock. If that one has one in it then It's been put in afterwards. If it needs oil then use Honda MTF, Redline MTF, or some 30 weight (ghetto imho).
Old Feb 23, 2003 | 08:42 AM
tominos's Avatar
i think its 75 - 90. i used redline mtl and it's gl-4 spec. i dunno about lsd equipped trannie's though, should be the same.
Old Feb 23, 2003 | 01:34 PM
AzG35's Avatar
Default Re: NEED HELP, LSD Tranny oil......... (BabyDaddy)
Some JDM GSR's come with LSD. I use Honda MTF with a Quaife LSD, works fine for me.
Old Feb 23, 2003 | 02:29 PM
eg6ajk's Avatar
Default Re: NEED HELP, LSD Tranny oil......... (AzSi22)
use only honda MTF for stock or gear type LSDs. gear oil is way to heavy.
use mineral type 30-40 weight oil ( no need for synthetics).
KAAZ or other clutch type LSD will require their oil (ie. kaaz oil)
Old Feb 23, 2003 | 03:59 PM
altoid's Avatar
Default Re: NEED HELP, LSD Tranny oil......... (eg6ajk)
SiR and SiG JDM of course came with lsds
Old Feb 25, 2003 | 03:25 PM
sleedawg's Avatar
a few questions... who told you you need gear oil? the previous owner or a mechanic... if i'm correct in guessing... you're hearing a crunching noise and you think it's wierd? if so... you won the lottery and got a Kaaz LSD in there... get Kaaz tranny fluid, or else you risk damaging the Kaaz. if you just need fluid in the tranny... go with the Redline MTF 75w90 GL-4... works well w. B-Series trannies... more info on the LSD would help alot...
[Modified by sleedawg, 12:26 AM 2/26/2003]
Old Feb 25, 2003 | 10:09 PM
Default Re: NEED HELP, LSD Tranny oil......... (sleedawg)
i guess a crunching noise. it makes a poping sound, you can hear the tires like barking on pavement when you turn sharp. two people told me that but they are not the most reliable. anyway we have bigger fish to fry. the motor is making a funny noise almost like it hasen't had a valve adj. in 50,000 miles. not sure going to look at it this weekend. thanks for the input everyone, its been helpful.
Travis
rzz
Nov 17, 2010 01:52 AM
EHondaD6
May 14, 2007 08:38 AM
rhdsirrex
12
Nov 12, 2005 05:46 AM
dtran002
Dec 8, 2004 08:23 PM
satan_srv
Oct 8, 2002 12:57 PM
