need help with inner cv joints (PICS)
Old Sep 14, 2004 | 05:55 PM
danewers's Avatar
Default need help with inner cv joints (PICS)
first of all this is an '89 accord 4dr manual
as you can see in the first pic, the wall of the inner joint cracked and broke and made a nice hole, so i want to replace this piece but how do i remove it from the transmission?
heres where i tried to pry it out with no luck.
and this is a pic of the inboard aside of the axle that goes into the inner joint in the first pic.
i'm kinda lost on what to do. this is my first time working on a front wheel drive car and this is all foreign to me. i cant get the inner joint out of the transmission, im also not sure what the part is called so i dont know what to look for when it comes to finding a replacement part. any help would be greatly appreciated. thanks!
-Dan
Modified by danewers at 7:11 PM 9/14/2004
Old Sep 14, 2004 | 06:06 PM
mmuller's Avatar
Mad Scientist
Default Re: need help with inner cv joints (danewers)
use a pry bar between the axle hub and the tranny.
once thats off go to autozone and get a lifetime warraty axle for like $60
Old Sep 14, 2004 | 06:09 PM
sol_guy8569's Avatar
To get that out you need to take a cro bar and pry it out. It is hard to get out because there is a lock ring in there which holds the axel in place. Once you get the ring out of the grove it should pull out fairly easy.
this should have three bearings that go on the three shafts which will ride in the groves in the where the old one cracked. Make sure that you have them the right way when you put it back together or you'll have more problems.
Also make sure that you have tranny fluid bcause you might lose some when you get that out of the transmission.
Good luck.
Old Sep 14, 2004 | 06:10 PM
Default Re: need help with inner cv joints (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">use a pry bar between the axle hub and the tranny.
once thats off go to autozone and get a lifetime warraty axle for like $60</TD></TR></TABLE>
Or just do as he says if you dont want to rebuild that one.
Old Sep 14, 2004 | 06:13 PM
danewers's Avatar
Default Re: need help with inner cv joints (sol_guy8569)
where exactly is the lock ring? is it in the groove that i'm trying to pry in?
Old Sep 14, 2004 | 06:57 PM
92bubblesi's Avatar
The lock ring is at the end of the shaft. You wont be able to see it until you get the shaft out of the tranny. Use a pry bar to get it out.
You are better off getting a new one rather than trying to rebuild it since that piece is shattered. You might want to put the boot back on the joint after you get it out or they might not give you your core charge back due to the shattered piece Some places are kinda **** about that.
Old Sep 14, 2004 | 11:33 PM
danewers's Avatar
Default Re: need help with inner cv joints (92bubblesi)
thanks for the suggestions guys! i'm gonna try them out tomorrow after work. i will get back to you guys and let you know how things go. i'm sure i'll have more questions thanks again!
crx18c1
10
Apr 17, 2007 10:17 PM
usdm97DC4
Jan 31, 2006 02:50 PM
si 1
10
Dec 29, 2005 03:32 AM
91ls-v
Jun 10, 2003 05:04 PM
ImportHatch
Oct 26, 2002 10:26 AM
