need help b20 obd1 ecu throwing CEL 9
Old Aug 31, 2009 | 02:01 AM
civic-one's Avatar
Default need help b20 obd1 ecu throwing CEL 9
Hi my car jsut started feeling wierd and CEl went on code 9. What can be wrong with the car is the block messed up or is it just sensors the car is drivable revs fine and all power still there the thing is when at idle and you tap the gas a little it kinda stutters and then revs fine driving it and stuff. Whats wrong with the car and where is this sensor located?
Old Oct 20, 2015 | 10:42 AM
Krazy613's Avatar
Default Re: need help b20 obd1 ecu throwing CEL 9
Just incase someone doesn't know cel 9 is a sensor in the distributor. I hear alot that it could be loose wiring. I have this code comes on at idle or random driving but when I turn car off and restart it it's gone. Since on the keys second click the car not running so no check engine light. Till random idle or just cursing.
Old Oct 20, 2015 | 01:41 PM
v4lu3s's Avatar
RTFM
Get your factory service manual out and run the diagnostic for code 9....
Old Oct 20, 2015 | 04:35 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/acura-integra...butor-3248502/
89crxsi89
Mar 20, 2010 11:39 PM
tazeat
10
Dec 3, 2008 09:28 PM
perpetualburn
Jan 13, 2008 12:43 AM
TylerC
Aug 18, 2005 10:28 PM
