NEED: d15b2 firing order HELP!
Old Aug 20, 2005 | 03:42 PM
beedoublejay's Avatar
Default NEED: d15b2 firing order HELP!
Please somebody, the search is not working and I want to start my car!
TIA
Old Aug 20, 2005 | 04:00 PM
Default Re: NEED: d15b2 firing order HELP! (beedoublejay)
HELLO? Is any body out there?
Old Aug 20, 2005 | 05:07 PM
civickiller's Avatar
1-3-4-2
Old Aug 20, 2005 | 07:25 PM
Default Re: NEED: d15b2 firing order HELP! (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">1-3-4-2</TD></TR></TABLE>
That does not help at all.
Old Aug 20, 2005 | 08:06 PM
JustinG60's Avatar
Not quite sure how that didn't help every 4cyl I've ever seen has a firing order of 1-3-4-2. But to specify that a little more cylinder 1 fires, then cylinder 3, then cylinder 4, then cylinder 2. Now for off the distributor.... On a honda cylinder 1 is on the driver side and works to the passenger side in order... 1-2-3-4. Now for spark plug wire placement on the distributor. Cylinder 1 should be on the lower left of the cap and work your way around the cap clockwise in the order 1-3-4-2 of the wires from the cylinder... Funny this is harder to explain than to show haha
Old Aug 20, 2005 | 10:39 PM
gsrious's Avatar
it should be just like this one... the blue leterings in the dizzy is the right ones. the ones over the cyclinders are correct aready.
i made the correction to this pic. i got it from another thread just not so long ago from here on honda-tech. i couldn't believe the misguidence people gave off.
well here you go.
h22vt
Aug 2, 2011 10:02 AM
type-GGSR
Nov 3, 2008 08:28 AM
playAho
Aug 16, 2004 12:11 AM
blue owns you
Apr 15, 2004 01:56 PM
jisu009
Jun 1, 2003 02:58 PM
