need advice on tranny remounting
need some advice on getting this damn tranny remounted i cant get it lined up. first project ive done on an engine and i had to drop the tranny (what was i thinkin) its a BEAR and 25 baby bears
dropped tranny to replace clutch, most of that ran pretty smooth but now i could really use some advice on gettin it back on
If everything is lined up properly it should go on without a hiccup as you tighten down the bolts. If not, then it's not lined up. It's that simple.
Yeah, sometimes you have to pull the tranny back out, spin the shaft a little and then try again. Sometimes it works and sometimes it doesn't.
Did you use a clutch alignment tool? If the clutch is not lined up properly, you can fight that tranny forever and not get it in. Put a very light coating of multi-purpose grease on the input shaft, it will slide in easier.
OBDII Integra
Sep 11, 2009 08:56 PM
ftrms
Mar 5, 2009 06:23 AM
vtecn8ive
23
Apr 23, 2006 06:59 PM
Lei Siew Long
Aug 16, 2001 02:58 AM
