Need advice on 1990 burning oil.
First post here so bear with me if you will.
My 90 accord with a 2.2 engine is a smoker with 211,000 miles. I just did a compression check on a cold engine and here are my results.
Cyl
#1 145
#2 143
#3 40
#4 160
I test each cylinder twice and came up with the same numbers.
Same results with a couple of squirts of oil on the #3 cylinder, the one I am most concerned with. The engine fouls the #3 plug within a week then I'm running on 3 cylinders with no more smoke.
What should I look at next? I cannot afford a full rebuild or replacement at this time but I may be able to get the head rebuilt.
Thanks in advance,
Bill
Cyl
#1 145
#2 143
#3 40
#4 160
Thanks in advance,
Bill
Jeff
Apr 30, 2005 04:01 PM
