Mysterious oil leak
Old Jul 20, 2012 | 08:25 PM
4tika4's Avatar
Default Mysterious oil leak
i have a b20b turbo. my tuner had my head rebuilt, and resurfaced. he put a new headgasket on it also. i picked my car up when it was done. it runs great. no smoke or anything. oil level stayed the same after driving 200 + miles but i noticed this oil leak
what could this be? i thought oil was coming from the headgasket. i have arp studs so i dont think the head lifted. plus it runs amazing and doesnt smoke at all. i think i noticed a little oil in the middle to bottom portion of the timing belt cover
Old Jul 20, 2012 | 08:36 PM
John M's Avatar
Default Re: Mysterious oil leak
your cam seals are leaking.
Old Jul 20, 2012 | 09:43 PM
4tika4's Avatar
i couldnt see any oil on the timing belt itself. should i replace it too if i have to do the seals?
Old Jul 21, 2012 | 06:08 AM
John M's Avatar
your tbelt should be fine but i would replace it to while your in there. also check your valvecover gasket too.
Old Jul 22, 2012 | 01:45 AM
slowcivic2k's Avatar
Inspect the timing area seals (cam/crank) and replace as required.
What kind of system are you using to evacuate the crankcase? If you do not have adequate ventilation in the PCV system, you will continue to blow past seals and gaskets.
ryaldin
Jan 26, 2015 11:39 PM
1701j
Honda Civic (2001 - 2005)
Apr 5, 2009 06:32 AM
jerbear!
May 7, 2005 09:31 PM
mike2016
Aug 23, 2002 05:13 AM
