My problem with a header.
Old Sep 9, 2002 | 03:56 PM
alilboi504's Avatar
Default My problem with a header.
Ok here my problem. I have a 98 lx civic. I just brought a Hp racing header for it. The problem is that my car have two o2 censors. The header only has only one slot for an o2 sensor. What should i do? Should i try to link the two o2 sensor together?
Old Sep 9, 2002 | 06:29 PM
IlikeTODA's Avatar
Default Re: My problem with a header. (alilboi504)
I believe you have the engine where the cat is up in the front of the engine, correct? If so you will need to screw the primary into the header. Then plug the secondary into the harness and I have heard you can make a bracket to mount it somewhere in the engine compartment. You arent going to be able to screw it into the exhaust or you will def throw a code since you will have no cat. I have heard that you should wrap it in aluminum foil to prevent the elements from getting to it.
Thanks, J
[Modified by IlikeTODA, 9:30 PM 9/9/2002]
styqe
Apr 14, 2013 07:10 PM
RVARGAS64
Oct 10, 2007 05:53 PM
YEE*MagicEK20kombobomber
Feb 29, 2004 08:04 PM
jbstran
Feb 26, 2004 05:39 PM
AirWaveGT
Mar 4, 2003 08:42 PM
