my power door locks aint working
i have a 98 integra ls coupe.. the power doorlocks aint working when i hit the switch.. the guy i bought the car from said it has to do something that start with the letter "A"
maybe a module box or something
yes i checked all the fusses and everything is fine..
any suggestions?
any suggestions?
any suggestions?
The power door lock circuit is built in to the drivers side controls. Try manually actuating the lock solenoid by unplugging the harness on each side and feeding it 12V. If they both work, check for an open in the wires that run around the front of the cabin between the doors.
thanks for the info but
hook on phonics is for learning to read.....
but ill try what you suggested .
and ps sometimes i mistype, cause i type fast and my mind dont catch up with my fingers
Could also be that you need a new actuator. There like $15. That's what happened to me on my passenger side, the drivers side would open and close but the passenger side would either just stay in the same postion or SOMETIMES it would open. Changed the actuator for that door and problem gone.
thanks
any pics of where this is or what it looks like?
[Modified by JdmTeg97, 11:32 AM 3/30/2003]
im just giving you a hard time. if i was really that upset by your spelling and typing, i probably wouldn't have tried to help
gribbs
Apr 11, 2003 04:52 AM
