Is my piston rings a goner?
GSR motor consumes about 1-1.5 quart of oil in between oil change (every 3000-3500 miles) and the muffler shoots out white/blue smoke when driving hard sometimes.
What is going on? Time to replace the piston rings? Total rebuild?
Thanks.
Thanks.
Do a compression test, and a leakdown test. Maybe it's just a blown headgasket. Do these and then start replacing stuff.
By the way, the motor runs 14.7 consistany in a 98 hatch on street tires 15"
So the power is there, it just take lots of oil and shoot out smoke (white/blue)
listen to the advice given. Doesnt matter what the car runs, if its blowing a lot of smoke something is wrong. Or you can just ignore it and replace it when it blows up (which is the expensive alternative).
i did a compression test for him. it reads 210psi 185psi 210psi 210psi (5 cranks)
it seems like the 2nd cylinder is weak. we drop very little oil on the 2nd cylinder
and the compression went back up to 210psi. so i guess the rings are bad on the
2nd cylinder? thanks
by the way, i have no access to a leakdown tester so i didn't do that.
but the compression test was done as i said on my previous reply.
any commets? thanks
any commets? thanks
i think its really gradual wear man. us ITR guys go through a .5-1.0 qt of oil between changes, but our motors are known to burn oil. if its not happening all the time or billowing smoke constantly i dont think its time for a full rebuild.
white/bluish smoke. i dont think your car does that does it?? thanks
[Modified by fwu, 5:50 AM 11/5/2002]
You can have good compression and still have bad oil rings or oil seals. Leakdown won't show either of those problems. If no probs with overheating or loosing coolant, then it has to be oil rings or oil seals in the head causing the smoke. Also could have out of round cylinders which would require a complete rebuild. You need to measure the cylinders for taper and roundness when you pull the pistons to re-ring.
[Modified by earl, 6:03 PM 11/4/2002]
interestingly enough, i also go through 1qt of oil per 1000 miles...however, i do not see any smoke out the back, nor do my friends...they report that occasionally, on a 2-3 shift, some might puff out, but its light... i'll try the tests mentioned above and report my findings,...
I got one in for repair a month or so ago that was using 1 quart every DAY.
Wow! So should i even bother fixing this now? Or just keep running it until it gets worse? Then fix?
do you run in vtec a lot? on my old prelude it would burn oil like it's going out of style when i ran in vtec. after a fun weekend i'd usually need to add almost a quart, but if i drove sedately, it wouldn't need any at all.
you can build your own leakdown tester for cheap... go here:
http://www.lafishmag.com/LeakDownTester.html
This is exactly the way it is with my car. i tend to hit vtec every time i drive the car
....i drive it hard...very hard.
what do you mean by this? what does tuning have to do with worn cylinder walls?
