my D16y8 engine came with a knock sensor!!!
or so.. at least my CEL tells me. I just threw a 23 which is the knock sensor on my d16y8. Any body have a clue why? I just installed the hondata gasget.. i was behind the block alot when i was wrenching that last manifold bolt on!
thanks,
bryan
[Modified by brcivic411, 7:41 AM 7/22/2002]
thanks,
bryan
i'm actually pretty sure my engine doesn't have a knock sensor.. just trying to figure out why i threw that code. even if there's a plug there, how could that have thrown the code unless it's tied into the ecu?
hmmm...
hmmm...
you have a knock sensor...its right above the oil filter, with the plug removed the sensor is green ( i think) anyway,you should get a helms manual for your engine...
ok, i have to confess that I was wrong.
the d16y8 DOES have a knock sensor: http://www.hondaautomotiveparts.com/...+BLOCK-OIL+PAN
i don't believe the d16z6 does: http://www.hondaautomotiveparts.com/...+BLOCK-OIL+PAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brcivic411 »</TD></TR><TR><TD CLASS="quote">i do have a helms manual.. but i was always told that the D series did not have knock sensors... I'm confused <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emcrook.gif" BORDER="0"> </TD></TR></TABLE>
You do have a knock sensor. Check the plug ( b/w intake manifold and oil filter) you could have just knocked it loose or pulled on the wiring to the plug.
redpeppers
Sep 15, 2005 06:42 AM
y2ks2k
May 11, 2005 02:29 PM
vladd
Nov 30, 2002 04:15 PM
