my d16y7 shake like crazy Help!!!
just purchased a hatch with d16y7. after replacing the battery fuse, the car start. but the whole engine shake like crazy. the first thing that came to my mind is probably the valve need adjustment or the vacumm leak. check the gap and yes some of the exhaust valve is a little to tight, but when I put the cylinder no 4 to tdc the piston seems to be stuck and dont want to go up. cylinder 1,2,3 seems to be find. anybody have any experience with this?
Ughh. Iwould start with a compression test. If piston is not traveling in the bore you have a major mechanical malfunction. I could not see this being likely if the engine is normal sounding while running... aka not knocking internally.
nemesis25
Jan 12, 2015 04:17 PM
t-town_ep
12
Feb 20, 2012 04:51 AM
724chris
Nov 1, 2009 05:47 PM
