Mufller tip size??? Need Quick Answer *pics*
Old Feb 19, 2006 | 12:20 PM
import810's Avatar
Default Mufller tip size??? Need Quick Answer *pics*
I just had my exhaust done with jdm itr 4-1 header/flex pipe/hi flow cat/ 2.5" piping/ es oval. MY problem is that he welded on a 2.25" pipe to the end of the muffler which is 2.5". Would this restrict my air flow and should I have him cut it off and put a 2.5" one on?? The whole point of my exhaust was to have a full 2.5" exhaust.
Modified by import810 at 1:45 PM 2/19/2006
Old Feb 19, 2006 | 12:26 PM
veggiemaster's Avatar
Default Re: Mufller tip size??? Need Quick Answer *pics* (import810)
I would cut it off and leave it off. Having a polished muffler welded to a mild pipe looks pretty tacky.
Old Feb 19, 2006 | 12:37 PM
JDMC-Kamel's Avatar
Default Re: Mufller tip size??? Need Quick Answer *pics* (veggiemaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster &raquo;</TD></TR><TR><TD CLASS="quote">I would cut it off and leave it off. Having a polished muffler welded to a mild pipe looks pretty tacky.</TD></TR></TABLE>
+1
Old Feb 19, 2006 | 12:44 PM
import810's Avatar
Default Re: Mufller tip size??? Need Quick Answer *pics* (JDMC-Kamel)
hmm if I cut it off then the muffler will look weird because ii sits so far back. Should I have him cut the tip off and move the hangers farther back? Also just wondering will the TIP restrict my airflow because of the diameter difference?
Old Feb 19, 2006 | 02:15 PM
ccivic's Avatar
Yes, it will restrict flow, and it looks tacky as fock.
Old Feb 19, 2006 | 02:48 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Mufller tip size??? Need Quick Answer *pics* (ccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it will restrict flow, and it looks tacky as fock.</TD></TR></TABLE>
Old Feb 19, 2006 | 09:38 PM
Azndude1983's Avatar
well..it's kinda ghetto looking with the tip welded to your stock pipe. As air flow restricting..I don't think so. It wouldn't make any diff cause all you're adding on is just the tip of your stock muffler. Just wondering, are you trying to have some sound out of your muffler?? If so, a cheap way is to cut off your resenator (if that's how you spell) and replace it with a 2.5" pipe since that's your exhaust pipe is. It will make the sound diff.
Old Feb 19, 2006 | 11:47 PM
import810's Avatar
Default Re: Mufller tip size??? Need Quick Answer *pics* (Azndude1983)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azndude1983 &raquo;</TD></TR><TR><TD CLASS="quote">well..it's kinda ghetto looking with the tip welded to your stock pipe. As air flow restricting..I don't think so. It wouldn't make any diff cause all you're adding on is just the tip of your stock muffler. Just wondering, are you trying to have some sound out of your muffler?? If so, a cheap way is to cut off your resenator (if that's how you spell) and replace it with a 2.5" pipe since that's your exhaust pipe is. It will make the sound diff. </TD></TR></TABLE>
yea I thought it was gay too. I have no resonater so its kinda loud. I think I might have and 18" glasspack put in.
Old Feb 19, 2006 | 11:59 PM
whatever works for you man
Old Feb 20, 2006 | 07:37 AM
Jmunk's Avatar
I don't think that it's going to really hurt your performance too much, you might lose .037 of a hp, but nothing to lose sleep over.
Old Feb 20, 2006 | 07:39 AM
Wes V's Avatar
Due to the length of pipe, I don't think it would make any notable difference.
I would recommend that you have a chrome tip (that slides tightly over the tube) added for looks.
Wes
Old Feb 20, 2006 | 09:23 AM
Kataku2K3's Avatar
Default Re: Mufller tip size??? Need Quick Answer *pics* (Wes V)
Yea, pretty sure you're already getting restriction from the muffler ahead of it anyways. Even if you had straight 2.5" all the way back, and reduced it to 2.25" at the tip, I doubt you'd see any difference. Just a little extra velocity, which isn't exactly where you want it, but oh well...
HighRevn
Jan 6, 2007 01:24 PM
pnoi_01dc2r
May 22, 2006 09:42 PM
b16powwer
Jan 8, 2004 12:34 PM
EcstacyRaver
15
Aug 6, 2003 05:33 PM
sleeperaccordv6
Apr 9, 2002 01:03 PM
