more seafoam results...
Old Mar 8, 2004 | 04:26 PM
marc.ejay-twenty's Avatar
Default more seafoam results...
well i just got done doing a compression test after using half a pint of seafoam engine treatment with a half tank of gas. after track day, my compression numbers were all over the place. refer to this post:
https://honda-tech.com/zerothread?id=727981
anyways, after the harsh detonation, my motor put out 170-160-210-180 compression and i was pretty depressed about that. last time i put gas in, i mixed half a tank of gas (~5-6 gallons) with half a pint of the seafoam stuff. i have since filled up a new tank, so i decided to do a compression test. this time it put out 185-175-180-175.
this is on a b16 and i know that these numbers are not even close to stock b16 compression numbers, but i'm pleased with the results just because they're all within the same range. i didn't actually feel a physical performance difference after using seafoam (like some people claim), but these numbers lead me to believe that the stuff actually works
-marc
Old Apr 15, 2004 | 03:56 PM
keebler65's Avatar
Default Re: more seafoam results... (marcdogg816)
sounds like you had a lot of carbon build up on cyl#3 in order for it to drop the comression that much afterwards.
cheeblez
Aug 15, 2012 01:09 PM
Loud-N-Clear
May 1, 2007 07:13 PM
EFstyle
Nov 17, 2006 06:11 PM
homesauce
Jan 18, 2005 05:36 PM
JsNA99si
Jun 16, 2004 02:51 PM
