max capacity of stock fuel pump
Old Oct 2, 2003 | 01:33 PM
Hybrid Invasion's Avatar
Default max capacity of stock fuel pump
I have a 90 CRX with a b16. I'm considering getting an aftermarket fuel rail and FPR from AEM so i can bump up the fuel pressure from the increase in air that I will be getting from the Skunk2 IM i just got. The AEM FPR says it can be adjusted from 20psi to the maximum capability of the fuel pump. How much can the stock Honda fuel pump handle?
Old Oct 2, 2003 | 02:31 PM
Default Re: max capacity of stock fuel pump (Hybrid Invasion)
bump
Old Oct 2, 2003 | 03:43 PM
spaceman's Avatar
i got the skunk2 on my b16 and it works with the stock fuel system,but if i was going to replace my fuel pump then i would get a denso pump
Old Oct 2, 2003 | 03:51 PM
Default Re: max capacity of stock fuel pump (spaceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">i got the skunk2 on my b16 and it works with the stock fuel system,but if i was going to replace my fuel pump then i would get a denso pump</TD></TR></TABLE>nono, im asking how much the stock fuel pump can handle, because i'm getting a FPR and I want to know how much I can adjust the psi up to on the FPR using the stock fuel pump, or if it would make more sense to get an aftermarket fuel pump.
Old Oct 2, 2003 | 04:05 PM
junya16's Avatar
don't know for sure exactly how much a stock fuel pump can handle but i know its plenty for a b16 swap in your car....and if you do plan on doin more mods then a fuel pressure regulator would be in order but a fuel rail IMO would be overkill...good luck w/ your setup
Old Oct 2, 2003 | 05:10 PM
Default Re: max capacity of stock fuel pump (junya16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junya16 &raquo;</TD></TR><TR><TD CLASS="quote">don't know for sure exactly how much a stock fuel pump can handle but i know its plenty for a b16 swap in your car....and if you do plan on doin more mods then a fuel pressure regulator would be in order but a fuel rail IMO would be overkill...good luck w/ your setup</TD></TR></TABLE>well the reason why I ask is because people are telling me that if I put the Skunk2 IM on, i'm increasing the airflow in the motor, therefore i would need to increase the fuel pressure in order to compensate for the extra airflow. That's why I was asking about the maximum amount of psi the stock fuel pump can handle because i thought I would get a FPR and bump the fuel pressure up a bit.... I dunno...
integratypeRs
Dec 10, 2008 07:13 PM
b16hatche
Dec 22, 2005 04:13 PM
P@@RB@Y
Nov 29, 2005 07:07 PM
echo999
Mar 8, 2003 12:35 PM
