which MAP sensors are interchangable
Old Aug 17, 2002 | 09:38 PM
B18C-RnVA's Avatar
New User
Default which MAP sensors are interchangable
threw CEL 3 today. MAP. i have 95 gsr b18c1. im going to test the MAP tomorrow, but just wanting to know in case i need anew one..which one can i put on the motor. any B series map sensor..so and so on..also anyone have one they trying to get rid of cheap.
Old Aug 17, 2002 | 11:02 PM
91DA9's Avatar
Default Re: which MAP sensors are interchangable (B18C-RnVA)
Third Gen integras have their MAP sensors on the throttle body (I would imagine the corresponding Civic's are the same) Where as the second gen have the MAP sensors mounted to a bracket and have a vacum hose running to them. I'm sure with the right amount of work you could make any MAP sensor work but if your not up to that then I am pretty sure any MAP sensor from a same year Civic would be the same. Probably all the way up to '98 but I am not certain.
Old Aug 18, 2002 | 01:38 AM
sparkz's Avatar
all ob0 to obd2 map sensors will all plug up the same. only difference is how it gets its manfifold source
Old Aug 18, 2002 | 11:37 AM
B18C-RnVA's Avatar
New User
Default Re: which MAP sensors are interchangable (sparkz)
so i can use a G2 teg's map sensor and they plug up the same..can i put it on the TB
Old Aug 18, 2002 | 02:50 PM
frogsr's Avatar
the g2 integra map sensor runs off the firewall, not the tb. the b18c map is on the throttle body itself, so you can't retrofit this one onto your existing setup.
Old Aug 18, 2002 | 02:55 PM
Mikey3000's Avatar
any MAP sensor will work. some are mounted to the firewall with a hose running to it, other's are mounted right on the tb. it doesn't matter which one you use, it doesn't matter whether you mount the MAP sensor or not. you could just plug a vacuum hose to bottom of a TB mounted MAP and leave it dangling. mounting location doesn't matter.
Old Aug 18, 2002 | 03:01 PM
frogsr's Avatar
Default Re: which MAP sensors are interchangable (Salvatore Leone)
yes, you're technically correct and i agree... i was merely responding to his answer directly since he asked: "can i put it on the TB" in which case, he cannot. good looking out though...
journeyquest
Jul 23, 2014 02:58 AM
92lxsleeper
Jul 29, 2009 09:25 PM
88crxhfb16
Apr 16, 2005 05:59 PM
