Major bogging
Old Oct 8, 2002 | 11:53 PM
shift6's Avatar
Default Major bogging
I just swaped a b18b1 into my 95 civic but when ever i give it gas it will make up to about 2000-3000 rpm then bog down almost to die. It also has a rough idle but i have messed with the idle screw and throttle cable but i havent been able to settle it down. I have not yet been able to get the rpms over 3k yet. Any ideas. Thanks
Old Oct 9, 2002 | 12:21 AM
S13 slide's Avatar
Default Re: Major bogging (shift6)
have you checked the tp sencor?
Old Oct 9, 2002 | 12:25 AM
shift6's Avatar
Default Re: Major bogging (S13 slide)
how do you tell if it is working or not? The only problem that i do know of with it is that it does not have a gasket anymore.
Old Oct 9, 2002 | 02:13 AM
Tofurky's Avatar
what kind of gasket are you talking about?
also check your distributor/ignitor
Old Oct 9, 2002 | 09:36 AM
afterhourz's Avatar
you may have air in the cooling system , the idle air control valve will do exactly what you say if that is the case.
20vt_gtx
14
Dec 27, 2019 04:50 AM
ejvtec
Jan 26, 2011 07:33 AM
h-o-n-d-a
Aug 3, 2009 05:15 PM
95dc2teg
Sep 11, 2007 05:49 PM
neXus dc4
May 15, 2004 12:04 PM
