main bearings too loose?
Old Aug 5, 2010 | 09:31 PM
horn12007's Avatar
Default main bearings too loose?
alright building my boosted ls vtec. anyways first build so im a little worried bout the main bearing clearance. im using clevites and my clearance (after using plastigage) is right at .002 maybe a hair under at .0019 on all the bearings. I like that they are all about the same but they are on the loose end. I've heard a few people that run them at .002 but want some real experience with it. You guys think this will be ok for my car? (its not gonna be a racer but dont think its gonna be a daily driver either). any help would be appreciated
Old Aug 5, 2010 | 10:05 PM
JLSpecialties's Avatar
Default Re: main bearings too loose?
I would run it, but I like to run slightly loose clearances.
Old Aug 6, 2010 | 06:24 AM
horn12007's Avatar
do you notice any differences? run thicker oil?
Old Aug 6, 2010 | 06:25 AM
horn12007's Avatar
really need a few more opinions before I keep building it
Old Aug 6, 2010 | 06:59 AM
unusual71's Avatar
not a big deal just make sure you have a good oil pump since pressure will be down a little bit with the looser clearance.
Old Aug 6, 2010 | 07:37 AM
EG1834's Avatar
.002" is fine.
Performance engines need looser bearing clearances. A good rule of thumb is about .001" for every 1 inch of journal diameter. Looser bearing clearances will allow more oil to flow over the bearings, keeping them cooler, and giving the crank a little more room to move under the higher power a performance engine makes. Personally, I'd probably run it even a little looser, like .0025".
Old Aug 6, 2010 | 08:04 AM
horn12007's Avatar
well its not gonna be any super high performance. probably around 300 hp. thanx alot guys anybody disagree with me running it that way?
kyden
Mar 10, 2013 04:56 PM
Kris's turbo
Oct 26, 2011 07:06 AM
Datunnerkid
Feb 2, 2011 04:40 PM
AccordSleeperZzZ
Oct 23, 2007 04:31 PM
Sprayteg
Feb 14, 2004 06:03 AM
