Main battery fuse keeps blowing?
Old Jan 27, 2003 | 01:18 PM
Jdm_Rice_Monster's Avatar
Default Main battery fuse keeps blowing?
I just finished putting a new motor in my friends sohc vtec turbo dx coupe. The car keeps blowing the 80 amp main battery fuse. The car has tons of ricer accsesories, but I unhooked all of them he had ran, still blows fuses. Does anyone know where I should be looking to fix this problem. Also his old motor blew up and oil was every where including the engine harness, do you think that could short it out? thanks for any help.
Old Jan 27, 2003 | 01:33 PM
kyle h.'s Avatar
Default Re: Main battery fuse keeps blowing? (JdmRiceMonster)
look for loose or bad grounds. also you guys using the correct alternator? does it blow when its running or when u turn the key or when u connect the battery etc...
Old Jan 27, 2003 | 02:46 PM
boosted3g's Avatar
Default Re: Main battery fuse keeps blowing? (kyle h.)
Has he replaced the fuse at all in the past? Mines an integra but its a 100 amp. Maybe he has too small of a fuse in. Just a shot in the dark but id try the easiest steps first.
Old Jan 27, 2003 | 04:36 PM
Patch's Avatar
Default Re: Main battery fuse keeps blowing? (boosted3g)
I say voltage regulator
Old Jan 28, 2003 | 12:29 AM
Default Re: Main battery fuse keeps blowing? (CRX PAT)
It was fine before the swap, it blows as soon as we hook up the negative trminal. I am stumped.....
Old Jan 28, 2003 | 06:18 AM
kyle h.'s Avatar
try hooking the neg. terminal up first.
lakeviewman
Aug 8, 2025 02:07 PM
d0wnShiFt
Jan 6, 2011 03:00 PM
Mychal71
Sep 10, 2006 02:01 PM
mjrage
Jun 25, 2004 08:09 PM
rasta420
Nov 6, 2002 08:41 PM
