LSD how do you know if you have it?
Old Nov 7, 2003 | 03:05 PM
EG6[B16A1]'s Avatar
Default LSD how do you know if you have it?
I'am just confussed... with my car up on jacks...when you spin the front wheels, if both tires spin in different directions, does that mean I have LSD?
Old Nov 7, 2003 | 03:41 PM
iwhichisme's Avatar
Default Re: LSD how do you know if you have it? (EG6[B16A1])
if you can take both of your axles off, also the half shaft, and look through the whole, you have lsd. when i say "look through the whole", i mean you can actually look where your axles and half shaft once went, and see from one side to the other. There should be no obstructions, keeping you from seeing the ohter side. On some models the initials L.S.D is stamped on the casings also, but i would still check to make sure. Ive heard of importers taking the lsd out and putting in a regular diff.
Old Nov 7, 2003 | 04:17 PM
EpDarks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6[B16A1 &raquo;</TD></TR><TR><TD CLASS="quote">]I'am just confussed... with my car up on jacks...when you spin the front wheels, if both tires spin in different directions, does that mean I have LSD?
Yes that means you have LSD.
Old Nov 7, 2003 | 05:04 PM
sleepN's Avatar
You have LSD when you spin one tire and the other goes the same direction too. What you stated, you do not have LSD. The other way to tel is what iwhichisme said.
Old Nov 7, 2003 | 08:08 PM
mel_2kgsr's Avatar
or if you jack up the car and put it into gear and both wheels spin...only one spins if you don't have LSD
Old Nov 7, 2003 | 09:19 PM
dohcter g's Avatar
Default Re: (mel)
Just look through the tranny like chief said. If you can see all the way through with nothing blocking the view. This is LSD!
Old Nov 9, 2003 | 08:52 AM
brownshigh's Avatar
Default Re: (dohcter g)
the easiet and dumbfound way is when you pull out from making a right or left turn,the tires will be grabbing very hard with little throttle response
Old Nov 9, 2003 | 09:24 AM
doublejz's Avatar
Default Re: (brownshigh)
like mentioned, if you can see right through without restrictions you have it
Old Nov 9, 2003 | 09:40 AM
Foozball26's Avatar
Default Re: LSD how do you know if you have it? (EpDarks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EpDarks &raquo;</TD></TR><TR><TD CLASS="quote">
Yes that means you have LSD.</TD></TR></TABLE>
not always true, my quaife spins the tires in the same direction.
Old Nov 10, 2003 | 12:52 AM
_Endless_'s Avatar
Default Re: (sleepN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepN &raquo;</TD></TR><TR><TD CLASS="quote">You have LSD when you spin one tire and the other goes the same direction too. What you stated, you do not have LSD. The other way to tel is what iwhichisme said.</TD></TR></TABLE>
Old Nov 10, 2003 | 07:30 AM
EG6[B16A1]'s Avatar
Default Re: (_Endless_)
ok? I'm confused now
Old Nov 10, 2003 | 08:11 AM
Muckman's Avatar
Moderator in Chief
What tranny do you have and is it stock?
On jackstands spinning wheel by hand -
My GSR with Quaife: wheels spin in opposite directions
My GSR w/o LSD (stock): only one wheel spins
5th gen Prelude SH: wheels spin in opposite directions too - which is weird since the ATTS isnt a mechanical LSD.
Foozball26 - What car and tranny are you using and are you positive both wheels spin in the same direction when rotated by hand? Perhaps you mean they spin the same when in gear.
Modified by Muckman at 12:34 PM 11/10/2003
Old Nov 10, 2003 | 12:35 PM
Katman's Avatar
see through = LSD
if you see this bar = no LSD / stock diff
Old Nov 14, 2003 | 09:59 PM
831HondaAllmotor's Avatar
i had my car on jacks and tried spinning one tire and the other one didnt go anywhere.
any ways,i do have lsd.
Old Nov 14, 2003 | 11:44 PM
blackeg's Avatar
Default Re: (831HondaAllmotor)
this is definatly a stupid comment, but i feel i have to ask. when i was f'in around b4 i got new tires i was doin burnouts and whatnot, when i took off the ebrake and peeled out while driving- i left 2 strips of about the same amount of rubber about 20 or so feet long. if i didnt have an lsd shouldnt i have only left 1 track? also when i was replacing my axle again the other day i looked into the tranny and it had that bar in the diff between the axles, which should mean no lsd. im confused.
Old Nov 15, 2003 | 05:31 AM
owen_the_soyboy's Avatar
Default Re: (blackeg)
you can leave two tracks WITHOUT a LSD of course.
you are more likely to reap the benefits of a LSD during corner carving / autocrossing or circuit racing.
you guys with your method of checking for LSD by jacking up the front of the car and spinning a wheel... THE TRANNY MUST BE IN GEAR to perform this test.
and I dont even remember if the wheels rotate the same direction with LSD or if they are opposing.... but its in the archives!
Old Nov 15, 2003 | 06:31 AM
Audi RS4's Avatar
Lover
be a ******* man , find a nice concrete parking lot or road and do a 7.5 K clutch drop......if you leave to lines for a long time you have a LSD.
make sure it is longer than acouple of seconds because with or without a LSD, a short burnout will show two lines...
Old Nov 15, 2003 | 09:23 AM
Foozball26's Avatar
Default Re: LSD how do you know if you have it? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Foozball26 - What car and tranny are you using and are you positive both wheels spin in the same direction when rotated by hand? Perhaps you mean they spin the same when in gear.</TD></TR></TABLE>
Stock LS tranny with quaife, and yes when spun by hand the tires go in the same direction.
Old Nov 15, 2003 | 10:19 AM
MrTodd's Avatar
Default Re: LSD how do you know if you have it? (AK1200)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK1200 &raquo;</TD></TR><TR><TD CLASS="quote">be a ******* man , find a nice concrete parking lot or road and do a 7.5 K clutch drop......if you leave to lines for a long time you have a LSD.
make sure it is longer than acouple of seconds because with or without a LSD, a short burnout will show two lines...</TD></TR></TABLE>
You can still do the exact same w/out an LSD. The only way to really tell is to visually inspect the tranny's differential itself.... Any other way and you're just guessing.
Old Nov 16, 2003 | 05:18 PM
bogus_ek's Avatar
Default Re: LSD how do you know if you have it? (MrTodd)
wow... never believed there could be that much confusion on HT about a relatively simple thing. Katman has a nice post with really helpful pictures. That's how you determine if you have lsd.
Old Nov 16, 2003 | 06:54 PM
t3to4e's Avatar
Default Re: LSD how do you know if you have it? (bogus)
yes if you can see threw then you have a lsd
98oRange
Apr 8, 2005 06:45 PM
tallblondkid
32
Jul 11, 2004 08:36 AM
vteg97
Mar 6, 2004 07:05 PM
vteg97
Mar 6, 2004 02:53 PM
d mafia
Jan 18, 2002 09:52 PM
